icechieff Posted August 3, 2010 Share Posted August 3, 2010 EngineEW10 J4S 4 Cylinders2 litre 16 Valves Twin CamVariable valve timing (VVT)133 kw (180 bhp) at 7000 rpmMax. torque 202 Nm at 4750 rpm160 Nm at 2000 rpmCompression Ratio: 11:1Bore - Stroke (mm). 85X88Capacity: 1997 cm²PerformanceMax. Speed:220km/h1000 m standing start: 28 sec0 - 100km/h: 7.4 secAcceleration 60 - 90 km/h in 4th: 5.7 secAcceleration 80 - 120 km/h in 5th: 10.6 secEngine ManagementMAGNETTI MARELLI 6LP (RFK)GearboxBE4 5 Speed ManualGear selection linked via cablesClose ratio (Except first gear)GearRatioFirst2.923Second1.870Third1.360Forth1.051Fifth0.861Reverse*****Final Drive3.948 ClutchPlate Ø 228 mmOperated by a self adjusting cable. SuspensionModified geometryStiffer springs then the standard 206 Gti2 Tie rods in the rear suspension for improved stability EquipmentAutomatic Climate Controled A/CCD ChangerWipers with rain sensorAutomatic HeadlightsElectric retractable door mirrors SafetyTwo smart front air bagsTwo side air bagsFront belts with pretensioners and force limitersE.S.P Electronic Stability ProgrammeE.B.A. Emergency Brake Assist Wheels17" AlloyPirelly P7000 205/40 R 17W Front BrakesVentilated DiscsNominal disc thickness: 26 mm.Min. disc thickness: 24 mm.Brake calipers: BOSCH ZOHPiston Ø 54 mm Rear BrakesSolid DiscLoad compensatorNominal disc thickness: 8 mmMin. disc thickness: 6mmCalipers: BOSCH 4GPiston Ø 32 mm BodyFive colours are be availableAden RedAluminiumAgean BlueObsidienBianca WhiteColour coded rear spoiler, bumpers and side strips.Chromed twin exhaust tail pipes Link to comment Share on other sites More sharing options...
