MultiStranger Posted February 6, 2015 Share Posted February 6, 2015 (edited) Где то в районе грм.http://youtu.be/EZ8sIB_amMc https://plus.google....474105122371283https://plus.google....474105122371283https://plus.google....474105122371283https://plus.google....474105122371283 Edited February 6, 2015 by multistranger@yandex.ru Link to comment Share on other sites More sharing options...
Dimkin67 Posted February 6, 2015 Share Posted February 6, 2015 Ограничен доступ к видео. Link to comment Share on other sites More sharing options...
MultiStranger Posted February 6, 2015 Author Share Posted February 6, 2015 (edited) там ещё ссылка, работает? Edited February 6, 2015 by multistranger@yandex.ru Link to comment Share on other sites More sharing options...
Dimkin67 Posted February 6, 2015 Share Posted February 6, 2015 там ещё ссылка, работает?Нет! Link to comment Share on other sites More sharing options...
MultiStranger Posted February 6, 2015 Author Share Posted February 6, 2015 может водяной насос?http://www.youtube.com/watch?v=EZ8sIB_amMchttp://www.youtube.com/watch?v=OJpqxicRiCI Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 , Link to comment Share on other sites More sharing options...
Dimkin67 Posted February 7, 2015 Share Posted February 7, 2015 Скинь кожух, будет видно либо ремень трёт , либо помпа готовиться в лучший мир отойти. Link to comment Share on other sites More sharing options...
AlexelA Posted February 7, 2015 Share Posted February 7, 2015 ИМХО, помпа помирает... Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 (edited) may bee Edited February 7, 2015 by MultiStranger Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 (edited) п Edited February 7, 2015 by MultiStranger Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 Скинь кожух, будет видно либо ремень трёт , либо помпа готовиться в лучший мир отойти.Снимал. демпфер был. приклеил на 2 компонентный клей, недавно смотрел, держится мертво, но звук есть... ЗЫ: думал поМпа, снял грм глЯнул, люфта нет, крутанул не шумит, вроде впоряде... Кстати там какая то вода с маслом была залита, поменял на антифриз, такой звук появился... Link to comment Share on other sites More sharing options...
MultiStranger Posted February 7, 2015 Author Share Posted February 7, 2015 я думаю водяной насос, но товаришь по гаражу говорит, она у тебя не люфтит, не болтается, звуки кагда рукой крутишь не издает, нормальная... Link to comment Share on other sites More sharing options...
Мартын Posted February 7, 2015 Share Posted February 7, 2015 я думаю водяной насос, но товаришь по гаражу говорит, она у тебя не люфтит, не болтается, звуки кагда рукой крутишь не издает, нормальная...Помпа. Link to comment Share on other sites More sharing options...
AlexelA Posted February 9, 2015 Share Posted February 9, 2015 я думаю водяной насос, но товаришь по гаражу говорит, она у тебя не люфтит, не болтается, звуки кагда рукой крутишь не издает, нормальная...Это еще ни о чем не говорит... Link to comment Share on other sites More sharing options...
Микола ded Posted March 7, 2015 Share Posted March 7, 2015 включи поисковик на нашем форуме - тем про помпы откурили не один километр постов. Все сошлись во мнении, что одной помпы на две замены ремня ГРМ не хватает. Link to comment Share on other sites More sharing options...
MultiStranger Posted March 7, 2015 Author Share Posted March 7, 2015 включи поисковик на нашем форуме - тем про помпы откурили не один километр постов. Все сошлись во мнении, что одной помпы на две замены ремня ГРМ не хватает.Я недавно пыжа преобрел, так что бы помпа скрежетала ещё не слышал, в любом случае денег нет, летом может поменяю) Link to comment Share on other sites More sharing options...
Мартын Posted March 8, 2015 Share Posted March 8, 2015 Я недавно пыжа преобрел, так что бы помпа скрежетала ещё не слышал, в любом случае денег нет, летом может поменяю)Помпа булькает и скрежещет так,что можно думать уже хана мотору. Link to comment Share on other sites More sharing options...
Микола ded Posted March 8, 2015 Share Posted March 8, 2015 Помпа булькает и скрежещет так,что можно думать уже хана мотору.здесь не согласен. У меня на 406 слегка булькала, но старый механик сразу вынес вердикт Link to comment Share on other sites More sharing options...
Мартын Posted March 9, 2015 Share Posted March 9, 2015 здесь не согласен. У меня на 406 слегка булькала, но старыймеханик сразу вынес вердиктЯ же про свои наблюдения говорю! При 33000 км и 8 лет с рождения на собственном авто (406 COUPE) было так,что про помпу сразу и не подумал бы. Link to comment Share on other sites More sharing options...
Motoriuz Posted June 25, 2015 Share Posted June 25, 2015 Не могу понять, что за посторонний подвывающий звук при 1500-2000 оборотах, раньше может тоже был, да я не прислушивался особо. В видео слышно, особенно на 40 секунде. http://rutube.ru/video/691209319a2e0976f9f0df44cc4a8b54/ Link to comment Share on other sites More sharing options...
wuzzik Posted June 25, 2015 Share Posted June 25, 2015 как будто ремень какой то воет, или натяжной ролик Link to comment Share on other sites More sharing options...
Motoriuz Posted June 26, 2015 Share Posted June 26, 2015 как будто ремень какой то воет, или натяжной роликСегодня вроде как звук пропал, не ясно что это было. Link to comment Share on other sites More sharing options...
MultiStranger Posted August 4, 2015 Author Share Posted August 4, 2015 У меня все таки не помпа. 2 варианта: подшипник на кондее, или в головке блока...что то, на впускном распредвале демпфер отвалился, может вал подразболтал там что тои слышно курлыканье .... Link to comment Share on other sites More sharing options...
