Коды Ошибок Пежо 605
В этой теме нет ответов
  • Администраторы
  • 14 720 сообщений
1 850
  • ИмяДенис
    C5 X7 2008 2.0 143Hp MT
  • Мечтает оPeugeot 407 Coupe
**** ECU 605 V6 Fenix 3B ***
11 End test ***
12 Start test ***
13 Injection air temp sensor 4k@10C; 2,5k@20C; 680@55C 907
14 Cooling water temp sensor 4k@10C; 2,5k@20C; 680@55C; 230@90C 909
15 Fuel pump relais 807
21 Throttle spindle potentiometer 4,5V max swing on pin 9 770
22 Idling actuator / Idle speed regulator 432
23 Throttle spindle potentiometer idle value 0,5 +/- 0,1V between pin 9 and 17 (gnd) 770
27 Vehicle speed sensor R=300 Ohm on sensor; When driving 1,5Volt on pin 3 154
31 Automatic adjustment air/fuel ratio oxygen/lambda sensor too quick (disconnect heater element to resolve) 900
33 Inlet manifold air pressure sensor 400Pa=2,5V; 600Pa=1,25V between pin 33 and 17 (gnd) 903
34 Canister discharge valve (active carbon filter) 430
36 Relais oxygen/lambda sensor heater 818
41 Engine speed sensor 330 Ohm between pin 11 and 28; check isolation to ground 152
42 Fuel injectors 14 Ohm each injector (2-3 Ohm between pin 20/21 and pin 30) 570
43 Engine knock control loop correct fuel grade, mechanical state engine
44 Front anti-knock sensor 150
51 Oxygen/lambda sensor When engine hot and running should constantly
change from 0 to 1V on pin 35 from pin 32 (gnd) 900
52 Air/fuel mixture control loop inlet or outlet manifold leak
53 Sensor power supply 10-15,5V on pin 4 ECU from gnd (pin 1).
54 ECU malfunction 142
56 Anti-theft start code not entered 176
62 Rear anti-knock sensor 151
