aliks407
aliks407
Все публикации пользователя aliks407
  1. все понял обучения я делаю сканером,
  2. что то не могу найти можно сылочку
  3. что такое обучи.? лямбу проверяли вроде жива была и первая и вторая. вторая дурачалас как газ дал все продуло и заработала ок пришел ответ с Германие может кто переведетWhat does this mean?OBD Code P0170refers to This code is one that surfaces with certain makes of automobiles more than others. In writing this article I've added Mercedes-Benz-specific info since it seems that M-B (and VW) are most prone to having this P0170 surface along with misfire codes or other fuel trim codes. P0170 means there was a malfunction in the computer's control of the air:fuel ratio. It also indicates that the fuel trims reached their limit of adding fuel while trying to compensate for a actual or perceived rich condition. When the fuel trims reach their rich correction limit, the PCM (Powertrain Control Module) sets a P0170, indicating a problem or malfunction in the fuel trims. It may also have a P0173 referring to the same malfunction but on bank two. SymptomsPossible sumptoms of OBD code P0170Symptoms of a P0170 DTC may include: MIL (Malfunction Indicator Lamp) Illumination Start and stall Poor fuel economy Black smoke at tailpipe Hesitation/misfire at idle or under load CausesPossible causes of OBD code P0170Potential causes include a vacuum leak, unmetered air leaks Fuel saturated engine oil Leak in turbo air charge hoses (if equipped) Possibly bad O2 sensor (If Mercedes, may require adaptation with M-Benz compatible scan tool.) Oil contamination in MAF connector or O2 sensor connectors. Also check ignition coils, cam and crank sensors, and oil sensor for leakage contributing to oil intrusion in wiring harness. Defective MAF (Mass Air Flow) sensor (especially on Mercedez-Benz and other European autos. There are a lot of problems with aftermarket MAF sensors.) Defective fuel pressure regulator Leaking camshaft adjuster solenoids (Mercedes-Benz). NOTE: for some Mercedes-Benz models there is a service recall for a crankcase vent hose located under the intake manifold. It should be checked for leaks/cracking and also operation of check valve in the hose. The check valve should flow only one way. Possible SolutionsIt should be stated right off the bat that the most common problem associated with this code is the MAF sensor or air mass meter. This is especially the case with Mercedes-Benz and Volkswagen and other European cars. At time of writing, you don't normally see this code with American-made cars, and minimally with Asian, and, to be honest, I have no idea why. It appears to me that the PCM (powertrain control module) logic used by some European car manufacturers to set a P0170 (or P0173) fault code simply isn't used by American vehicle manufacturers. It is more common to see P0171, 0174, 0172, 0175 codes set with regard to fuel trim malfunctions on American cars. There is very little information on the setting conditions for a P0170, or P0173, but what information that is available almost seems to be a redundancy of the P0171,4,2 & 5 setting conditions. I'm sure there's a reason for it, but I can't get anyone to tell me what that is. The similarities between them may be why we don't see this code surface on domestic vehicles very often. It's simply unnecessary. So, simply put, if you have a P0170, your PCM noticed that the fuel trims reached their rich correction limit. Basically it's adding fuel to try to compensate for a lean condition, real or perceived. If you have this code and access to a scan tool, observe the MAF sensor reading in grams/sec. The reading will be different for different automobiles, so get a good spec. I'm going to stick with what would be normal for a Mercedes (1.8L), since they have the bulk of the trouble. Expect to see at idle 3.5-5 g/s (ideally). At 2500 RPMs with no load it should be between 9 and 12 g/s. On road test, at WOT (wide open throttle) it should be 90 g/s or well above. If it's not in specs, replace it. Be careful of Ebay MAFs. Often they don't work according to OE specifications. If the MAF checks out and there is no oil intrusion at the connector, check fuel pressure and ensure that there are no leaks at the regulator internally or externally. Check all vacuum hoses and confirm none are cracked, disconnected or missing. Make sure there are no vacuum leaks at the intake manifold gaskets or tears in the air supply hose. If the engine is turbo charged, be sure the hoses are in good condition and have no leaks. Leaking turbo pressure hoses could cause a rich condition. Inspect the condition of crankcase vent hose under intake manifold and operation of check valve in the hose. (In the "What are the causes?" section) If there doesn't appear to be any problems with the fuel pressure, MAF or vacuum hoses, then inspect the O2 sensor connectors for oil intrusion. A bad O2 sensor could cause a P0170, or P0173. Repair cause of oil leak and replace oil-fouled O2 sensor.
  4. а что по фосункам скажете вроде есть разница не долив это норма? Может под замену и чистку ультразвуком проделать? Или не парится поставить от волги форсунки ?
  5. проблемма в следущем пежо 407 2 литра 134 лошади 2005 года пробег 125 тысяч . расход бензина 16 до 19 л в городе.по утрам при температуре 3 градуса машину колбасит (не всегда чем ниже температура чем тяще летом такого нет) несколько секунд .мастера говорят о замени гидриков. менял на машине недавно бензонасос, свечи, заливал жидкость для промывки форсунок. масло ест на 5000 грам 300 400 заливаю мобил 3000 с допуском для пежо. также бросает масло в воздушный патрубок грам 30- 40 при больших скоростях сегодня провел диагностику двигателя выдает ошибку P0170. прошивка двигла стоит 2009 года проверил форсы там одна форса чутьчуть не доливает стиль езды тихий средняя скорсть 40 км проверил также лябму показание второй лябмы дико прыголо, после нажатие на газ стало работать плавно как и должно работать мне кажеться нужно почистить лябму. дросель чистый три раза мыл коды ошибок P0170 Diag Fuel System Верхний по запоху с глушака чуствуеться что бензин не догорает чтоли
